feng0hua0
Rest SOE problem
Discussion created by feng0hua0 on Jul 19, 2012
Latest reply on Jul 20, 2012 by ciava.at
Hi guys,
    I just start using SOE in ArcGIS Server 10.1 and find something strange here. When I create a RESTSOE project from Visual studio 2010 template, the handler is like this:
        private byte[] SampleOperHandler(NameValueCollection boundVariables,
                                                  JsonObject operationInput,
                                                      string outputFormat,
                                                      string requestProperties,
                                                  out string responseProperties)
            responseProperties = null;
            string parm1Value;
            bool found = operationInput.TryGetString("parm1", out parm1Value);
            if (!found || string.IsNullOrEmpty(parm1Value))
                throw new ArgumentNullException("parm1");
            string parm2Value;
            found = operationInput.TryGetString("parm2", out parm2Value);
            if (!found || string.IsNullOrEmpty(parm2Value))
                throw new ArgumentNullException("parm2");
            JsonObject result = new JsonObject();
            result.AddString("parm1", parm1Value);
            result.AddString("parm2", parm2Value);
            return Encoding.UTF8.GetBytes(result.ToJson());
After adding this soe file to ArcGIS Server and invoke the rest service at:  http://localhost:6080/arcgis/rest/services/demo/MapServer/exts/RestSOE/sampleOperation?parm1=1111&parm2=222&f=pjson
the soe will throw ArgumentNullException when it trying to retrieve parm1 value.
Then I change handler code to:
            object parm1Value;
            bool found = operationInput.TryGetObject("parm1", out parm1Value);
            if (!found || parm1Value == null || string.IsNullOrEmpty(parm1Value.ToString()))
            object parm2Value;
            found = operationInput.TryGetObject("parm2", out parm2Value);
            if (!found || parm2Value == null ||  string.IsNullOrEmpty(parm2Value.ToString()))
            result.AddString("parm1", parm1Value.ToString());
            result.AddString("parm2", parm2Value.ToString());
            string aaa;
            found = operationInput.TryGetString("parm1", out aaa);
            if (!found || string.IsNullOrEmpty(aaa))
                result.AddString("parm1Exist", "False");
            else
                result.AddString("parm1Exist", "True");
then result json will be:
 "parm1": "1111",
 "parm2": "222",
 "parm1Exist": "False"
It looks like JsonObject.TryGetObject() function works fine while JsonObject.TryGetString() not working.
Am i right?
Outcomes
