How to add ITable to ArcMap TOC
1709
07-16-2012 07:50 AM
YimanSong
Is there anyway to add ITable to ArcMap TOC? I'm trying to edit a table which is added through WorkspaceFactory.OpenFromFile. But I get the error "Error HRESULT E_FAIL has been returned from a call to a COM component", see the code below. I found out that if I add a featurelayer along with the table and add the featurelayer to TOC, I don't get the error. Any suggestions?
            IWorkspaceFactory pWorkspaceFactory = new SdeWorkspaceFactory();             IWorkspace workspace = pWorkspaceFactory.OpenFromFile(path, 0);             IPropertySet propSet = workspace.ConnectionProperties;              IFeatureWorkspace pWorkspace = pWorkspaceFactory.Open(propSet, 0) as IFeatureWorkspace;             ITable table = pWorkspace.OpenTable("GISLCSA.GISEDITOR.MetaID");             ILayer tableLayer = table as ILayer;             pMetaIDTable = table as ITable;              UID uid = new UIDClass();             uid.Value = "esriEditor.Editor";             IEditor editor = m_application.FindExtensionByCLSID(uid) as IEditor;              if (editor.EditState == esriEditState.esriStateNotEditing)             {                 try                 {                     editor.StartEditing(workspace );                 }                 catch (Exception e)                 {                     MessageBox.Show(e.Message);                 }             }
NeilClemmons
Honored Contributor
You can create a new IStandaloneTable, set it's Table and Name properties and add it to the map via IStandaloneTableCollection.  You could also just start your edit session using IWorkspaceEdit instead of using the Editor extension.
NeilClemmons
Honored Contributor
YimanSong
Perfect! Thank you Neil!
