Visible Layers in a DynamicMapServiceLayer
3754
9
07-14-2012 10:50 PM
NicoTek
New Contributor III
Hello Everyone,
I have the following layer,
ArcGISDynamicMapServiceLayer layer = new ArcGISDynamicMapServiceLayer(my_map_server_url);
And i know i can add a int array to the constructor to decide which layers are visible in the following way:
ArcGISDynamicMapServiceLayer layer = new ArcGISDynamicMapServiceLayer(my_map_server_url,new int[] {0,1,2});
but can I change the visible layers programmatically?
For example I would like to have a button where the user can select which layer to see.
How can I achieve this?
Thanks!
ViridianaGO
New Contributor III
Hi, what I do is something like this, depending what you want:
ArcGISDynamicMapServiceLayer agdms = new ArcGISDynamicMapServiceLayer(my_map_server_url); ArcGISLayerInfo[] arcgisLayerInfo = agdms.getAllLayers();          for(int j=0; j<arcgisLayerInfo.length; j++) {    arcgisLayerInfo.setVisible(my_boolean_value); }
Let me know if it helps you.
Town_ofSnowflake
As a very general response, you should be able to:
XML:
1) Create a button in your layout
2) Specify a method that is called when the button is clicked
Java:
3) Define a method for your activity that redefines which layers are visible using cases
Let me know if you want more clarification.
NicoTek
New Contributor III
@meloking
I understand how to create buttons and specify methods.
My question is specifically about how to change the visible layers in a DynamicMapServiceLayer.
So in your post it would be what is the Java code that allows me to redefine which layers are visible.
Thanks again.
ViridianaGO
New Contributor III
NicoTek
New Contributor III
Thank you Diana, that seems to be the right way.
What I did was to create a switch statement that removes the layer and calls it again with the layers I want to see : S
Basically this:
     map.removeLayer(1);
     layer = new ArcGISDynamicMapServiceLayer(my_map_server_url,Array_with_layers_I_Want);
     map.addLayer(layer);
ViridianaGO
New Contributor III
Yes, that could be another way to solve that, as I told you, depending your needs, I have a ExpandableListView and I use setVisible method from ArcGISLayerInfo.
Recive greetings from México 😉
MiriEshel
New Contributor III
I have a dynamic layer. I use Lavascript API 3.2.
I want to toggle visibility of DynamicLayer on each click on the button.
I tried to remove it in many ways but it is still show on the map.
The latest try is attached:
      elecUrl = "http://gis2012.emap.co.il/arcgis/rest/services/CompareElections/MapServer";
         elecLayer = new esri.layers.ArcGISDynamicMapServiceLayer(elecUrl, {
             "id": "elec",
             "opacity": 0.7
         if (elecLayer != null) {
             if (map.layerIds.length > 1) {
                //var visible = [];
                //visible.push(-1);
                //elecLayer.setVisibleLayers(visible);
                map.removeLayer(elecLayer);
            else {
                 elecLayer.setVisibleLayers([0]);
                 var symbol = new esri.symbol.SimpleFillSymbol();
                 symbol.setColor(new dojo.Color([150, 150, 150, 0.5]));
                   var renderer = new esri.renderer.UniqueValueRenderer(symbol, "WinningParty");
                 renderer.addValue("א�?ת", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([238, 31, 58, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([132, 164, 203, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([121, 71, 0, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([126, 149, 102, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([39, 166, 117, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([71, 102, 36, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([160, 160, 225, 1])));
                 renderer.addValue("�?�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 140, 0, 1])));
                 renderer.addValue("�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([91, 91, 169, 1])));
                 renderer.addValue("�?�?�?", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([25, 106, 255, 1])));
                 renderer.addValue("�?רץ", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([0, 206, 0, 1])));
                 renderer.addValue("עם", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([182, 212, 168, 1])));
                 renderer.addValue("שס", new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([136, 111, 69, 1])));
                 // set up the parameters for the dynamic layer
                 var optionsArray = [];
                 var drawingOptions = new esri.layers.LayerDrawingOptions();
                 drawingOptions.renderer = renderer;
                 optionsArray[0] = drawingOptions;
                 elecLayer.setLayerDrawingOptions(optionsArray);
                 // add the layer to the map
                 try {
                     map.addLayer(elecLayer);
                 catch (err) {
                     console.log(err.message);
What do I do wrong?
As you can see in comment, I tried setVisibleLayers but no impact on the map - it still shows the layer.
Please try to help ASAP.
Thanks a lot,
Miri
Thanks a lot,
Miri
deleted-user-ATjHIWsdQYmT
Occasional Contributor III
Might want to post this over in the Javascript forum, not the Android API Forum...
http://forums.arcgis.com/forums/15-ArcGIS-API-for-JavaScript
MiriEshel
New Contributor III
Oops. I'm sorry....
Thanks.
Miri
weiyunli
I did as you said before, but the program still had problems.Can you help me?
[ATTACH=CONFIG]29924[/ATTACH]
my code
dlayer = new ArcGISDynamicMapServiceLayer(url);
  mMapView.addLayer(dlayer);
  ArcGISLayerInfo[] layinfo = dlayer.getAllLayers();
  layinfo[0].setVisible(true);
Thank you!
