GlobeControl Transparency FeatureLayer
832
5
07-10-2012 03:48 AM
FabrizioPuddu2
hi at all,
I'am try to use transparency on FeatureLayer (polygon featureclass) on GlobeControl. The featurelayer must be within a grouplayer, but I've also tried out and does not work. This is my code:
Dim pLayerEffects As ILayerEffects
pLayerEffects = pFLy
pLayerEffects.Transparency = 50
if I apply the transparency to grouplayer it work fine
thanks
fabrizio
FabrizioPuddu2
anyone can help me?
thanks
FabrizioPuddu2
to follow the source code that I used, the transparency on polygon does not work. Some ideas???
        Dim pFLy As IFeatureLayer
        Dim pFeatureClass As IFeatureClass
        Dim pFSelection As IFeatureSelection
        Dim pGlobeLayerProperties As IGlobeLayerProperties = Nothing
        pFeatureClass = CreateFeatureClass(esriGeometryType.esriGeometryPolygon)
        pFLy = New FeatureLayer
        With pFLy
            .FeatureClass = pFeatureClass
            .Name = m_NameLayer
            .Cached = My.Settings.UseCachedLayer
            .Selectable = True
            .DisplayField = "ToolTip"
            .ShowTips = True
            .ScaleSymbols = Me.m_SymbolProperties.Symbol_SizeFixed
        End With
        pLayerEffects.Transparency = 60
        m_objGlobeControl.Globe.AddLayerType(pFLy, esriGlobeLayerType.esriGlobeLayerTypeDraped, True)
        pGlobeLayerProperties = TryCast(Me.m_objGlobeControl.GlobeDisplay, IGlobeDisplayLayers).FindGlobeProperties(pFLy)
        pGlobeLayerProperties.BaseImageDrawingPriority = 1
          ' ----> Adding feature to feaureclass
         TryCast(m_objGlobeControl.GlobeDisplay, IGlobeDisplayLayers2).RefreshLayer(pFLy)
FabrizioPuddu2
anyone can help me?
AysberqTundra
Hello.
Following code worked for me in ArcMapAddIn.
ILayerEffects m_LayerEffects = ArcMap.Document.FocusMap.get_Layer(0) as ILayerEffects;
m_LayerEffects.Transparency = 50;
ArcMap.Document.ActiveView.Refresh();
I hope that will help you.
FabrizioPuddu2
thanks,
This is the same code that I use with mapcontrol and working properly, but does not work when I work with globecontrol
some advice?
thanks
