Step properties not sticking in workflow design
1162
07-07-2012 02:58 PM
FraserHand
Occasional Contributor III
Has anyone seen setting not sticking in the workflow design? I have steps where I set the job status, and ok -> ok, yet when I check the step again the status has not been set. I have also seen the step can be skipped check and automatically execute check also not save settings. Has anyone experienced this? Is it something to do with the size of the workflow? It's a bit frustrating as now I have to check every step at least twice, and I have to set the same properties on steps 2 or three times before the finally stick.
Running 10 SP4
Fraser
