Save object IFeatureclass
715
07-04-2012 03:43 AM
HectorSanchez_Molinero
I have created an object (type ifeatureclass) in the memory.
How do I do to guard this ifeatureclass where I want (route and name)? (shape in hdd)
There is some option for sobreescribirlo if already it exists?
Regards. Thank you.
KenBuja
MVP Esteemed Contributor
You can use IFeatureWorkspace::CreateFeatureClass to save it. Here's an example (written for VBA, but easily transferred to .NET). There's also a snippet available in Visual Studios called "Create FeatureClass", but you'd have to modify it a bit since it saves the featureclass to a geodatabase.
sobreescribirlo = rewritable
i can't edit my post
KenBuja
ok, thanks a lot.
regards.
