LuciH
basemap or featurelayer which one sets projection
Discussion created by LuciH on Jul 3, 2012
Latest reply on Jul 5, 2012 by jeff.pace
Hi All,
I have been playing around with trying to load data from a config.txt file
I am using the Basemap Gallery for my background maps and I am also loading several dynamic map service layers.  It seemed as though the projection was being set from the first feature layer loaded and not the first basemap loaded.
But, upon investigation it seems as though I am getting different projections based upon the method used to set the map extent.  Can someone explain to me what the difference is between the two methods below because when I use Method 1 everything lines up properly, but, when I use Method 2 my Basemaps are fine, but my dynamic feature layers are over in Africa...
Method 1:
All of the below is in my default.html file
var initExtent = new esri.geometry.Extent({"xmin":-9654356.83267948,"ymin":3553252.14612359,"xmax":-9631845.86180353,"ymax":3569377.06341259,"spatialReference":{"wkid":102100}});
map = new esri.Map("map", {
    extent: initExtent,
    slider: true,
    lods: lods,
    infoWindow: popup
Method 2:
This is config.txt
'DefaultExtent' : "-9654356.83267948, 3553252.14612359, -9631845.86180353, 3569377.06341259"
This is in my default.html file
var mapExtent = responseObject.DefaultExtent;
var mapExtent2 = mapExtent.split(',');
    slider: true,
    lods: lods,
    infoWindow: popup
map.setExtent(new esri.geometry.Extent(parseFloat(mapExtent2[0]), parseFloat(mapExtent2[1]), parseFloat(mapExtent2[2]), parseFloat(mapExtent2[3]),  new esri.SpatialReference({ wkid: 102100 })));
Luci
Outcomes
