add field to an IFeatureClass
3616
13
07-02-2012 11:50 PM
HectorSanchez_Molinero
Hello, I am beginning to programs with vb.net and c# and of arcobjects do not belong almost anything.
Can someone say to me how add a field (text or integer) to an object of type IFeatureClass and as put then information in him??
I try it this way:
' Create a new fields collection.
            Dim fields As IFields = New FieldsClass()
            ' Cast to IFieldsEdit to modify the properties of the fields collection.
            Dim fieldsEdit As IFieldsEdit = CType(fields, IFieldsEdit)
            ' Set the number of fields the collection will contain.
            fieldsEdit.FieldCount_2 = 1
            ' Create the text field.
            Dim textField As IField = New FieldClass()
            Dim textFieldEdit As IFieldEdit = CType(textField, IFieldEdit)
            textFieldEdit.Length_2 = 30 ' Only string fields require that you set the length.
            textFieldEdit.Name_2 = "Edificio_Afectado"
            textFieldEdit.Type_2 = esriFieldType.esriFieldTypeString
            ' Add the new field to the fields collection.
            fieldsEdit.Field_2(0) = textField
' Here it gives mistake
' Add the field.
            featureClass2.AddField(fields)
Thank you very much. Bye.
' Add the field.
I have arranged it this way:
' Add the field.
            featureClass2.AddField(fieldsEdit.Field(0))
But on having tried to put a Alias does not it take it,
textFieldEdit.AliasName_2 = "Edificio_Afectado"
why it can be?
and as put then information in this new field??
DorisRiedl
Does your FeatureClass already exist (does it have the necessary fields)?
And what kind of mistake did you get?
regards
Doris
The mistake in the creation of the fields already is corrected.
I answer the featureclass of the existing one and I him add the necessary fields.
The problem is that it does not take the Alias of the new fields:
                short2FieldEdit.AliasName_2 = "Tipo_max_min"
                short2FieldEdit.Name_2 = "Tipo_punto"
I do not know like add the new information in the created fields.
Thanks a lot Doris.
Regards, Héctor.
FengZhang2
In order to modify a field's Alias name, you can use the IClassSchemaEdit::AlterFieldAliasName method.
Dim classSchemaEdit As ESRI.ArcGIS.Geodatabase.IClassSchemaEdit3
classSchemaEdit = DirectCast(featureClass2, ESRI.ArcGIS.Geodatabase.IClassSchemaEdit3)
Dim schemaLock As ESRI.ArcGIS.Geodatabase.ISchemaLock
schemaLock = DirectCast(featureClass2, ESRI.ArcGIS.Geodatabase.ISchemaLock)
schemaLock.ChangeSchemaLock(ESRI.ArcGIS.Geodatabase.esriSchemaLock.esriExclusiveSchemaLock)
classSchemaEdit.AlterFieldAliasName("Tipo_punto", "Tipo_max_min")
schemaLock.ChangeSchemaLock(ESRI.ArcGIS.Geodatabase.esriSchemaLock.esriSharedSchemaLock)
Thanks a lot Doris.
Regards, Héctor.
Thanks a lot feng.zhang.esri.
It continues without me working. On having come to the new code it gives the following mistake:
"It is not possible to turn the object COM of the type ' System. __ ComObject ' to the type of interface ' ESRI.ArcGIS.Geodatabase. IClassSchemaEdit3 '. A mistake of operation happened due to the fact that the so called QueryInterface in the component COM for the interface with IID ' {4B35F814-0417-47E3-8DFC-CAD58746693B} ' generated the following mistake: not compatible Interface (HRESULT's Exception: 0x80004002 (E_NOINTERFACE))."
Also I have tried with CType instead of DirectCast and neither it works.
regards.
FengZhang2
Please try to replace the following two lines:
with
Dim classSchemaEdit As IClassSchemaEdit3 = TryCast(featureClass2, IClassSchemaEdit3)
regards.
with
Hi, thanks feng.zhang.
I have just modified the code for:
                schemaLock = TryCast(featureClass2, ESRI.ArcGIS.Geodatabase.ISchemaLock)
it continues giving a mistake here, in this line:
I have tried to change DirectCast for CType and TryCast.
the mistake it is:
{"Referencia a objeto no establecida como instancia de un objeto."}
{ " Reference to object not established as instance of an object. "}
what can fail?
sreekarmasani
It is beeter to use geoProcessing tools instead of writing our own code if one is available in GPTools.
            Geoprocessor gProcess = new Geoprocessor();
            IVariantArray varArray = new VarArrayClass();
            varArray.Add(@"...\MyPGDB.mdb\DatasetTwo\Line_2");
            varArray.Add("MyNewField");
            varArray.Add("TEXT");
            gProcess.Execute("AddField", varArray, null);
