gislifb
Converting between coordinate-systems
Discussion created by gislifb on Jun 19, 2012
Latest reply on Jul 4, 2012 by gislifb
Hi
I recently started at the National Landsurvey of Iceland and I'm having a problem with programming a JS-mapviewer (don't really know how to describe it better).
So my problem is that I have a map where if you click it an alert box pops up (better for small mobile-screens than an infowindow) which contains the ISN93 and LatLong coordinates. I've been trying to code "around" an example on the JS API samples-site but the problem is that I'm not an experienced JS-programmer so I'm not figuring out how to project the point from ISN93 to LatLong coordinates.
I hope you can help, been trying this for some 4-5 hours now but not getting anything. I'll just paste the whole code here but my problem is with the "coordinates"-function.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
 <head>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title> Map with scalebar</title>
  <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
  <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; }#map{padding:0;}</style>
  <script type="text/javascript">
   var djConfig = {
    parseOnLoad: true
   </script>
   <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
    dojo.require("dojo.parser");
    dojo.require("dijit.layout.BorderContainer");
    dojo.require("dijit.layout.ContentPane");
    dojo.require("esri.map");
    dojo.require("esri.dijit.Scalebar");
    dojo.require("esri.tasks.geometry");
    var map;
    var gsvc = null;
    var pt = null;
    function init() {
     var initExtent = new esri.geometry.Extent({
      "xmin": 210000,
      "ymin": 275000,
      "xmax": 810000,
      "ymax": 705000,
      "spatialReference": {
       "wkid": 3057
     map = new esri.Map("map", {
      extent: initExtent
     var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://a1arc.lmi.is/arcgis/rest/services/kort-isn93/kort-medornefnum-isn93/MapServer");
     map.addLayer(basemap);
     gsvc = new esri.tasks.GeometryService("http://a1arc.lmi.is/arcgis/rest/services/Geometry/GeometryServer");
     dojo.connect(map, 'onLoad', function(scale) {
      var scalebar = new esri.dijit.Scalebar({
       map: map,
       scalebarUnit:'metric'
      //resize the map when the browser resizes
      dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
     console.log(gsvc);
     dojo.connect(map, "onClick", coordinates);
    function coordinates(evt) {
     map.graphics.clear();
     var point = evt.mapPoint;
     console.log(point); //works
     var symbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
     var outSR = new esri.SpatialReference({wkid: 4326});
     var graphic = new esri.Graphic(point, symbol);
     map.graphics.add(graphic);
     function projectToLatLong(point, outSR) {
      gsvc.project([point], outSR, function(projectedPoints) {
       pt = projectedPoints[0];
       console.log(pt); //doesn't work
     console.log(pt) //outputs null
     console.log("ISN93: " + point.x.toFixed(2) + " ; " + point.y.toFixed(2));
    dojo.addOnLoad(init);
   </script>
 </head>
 <body class="claro">
  <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false"
  style="width: 100%; height: 100%; margin: 0;">
   <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;"></div>
  </div>
 </body>
</html>
Outcomes
