Hello,I'm working on an Addin where I need to check if the user specified output feature class already exists. If it does then it needs to be deleted first before the new one is created.
IFeatureClass outputFeatureClass=null;
IWorkspaceFactory2 wsFactory = new AccessWorkspaceFactory() as IWorkspaceFactory2;
string fullDatasetName=gxDialog.FinalLocation.FullName.Replace(gxDialog.FinalLocation.Name,"");
fullDatasetName = fullDatasetName.Substring(0, fullDatasetName.Length - 1);
IFeatureWorkspace fWorkspace = wsFactory.OpenFromFile(fullDatasetName,0) as IFeatureWorkspace;
IFeatureDataset fDataset = fWorkspace.OpenFeatureDataset(gxDialog.FinalLocation.Name);
IFeatureClassContainer fcContainer = fDataset as IFeatureClassContainer;
try
outputFeatureClass = fcContainer.get_ClassByName(gxDialog.Name);
IDataset dataset = outputFeatureClass as IDataset;
dataset.Delete();
catch (System.Exception ex)
MessageBox.Show(ex.Message);
try
outputFeatureClass = fDataset.CreateFeatureClass(
gxDialog.Name, fields, null, null, esriFeatureType.esriFTSimple, shapeFieldName, "");
This logic works fine if the target database is a File Geodatabase (of course the workspacefactory in that case is different). However it doesn't work with a Personal Geodatabase. If the output feature class already exists, this is the exception message I'm getting on the delete operation ("tmp" is the name of the output feature class):"The database engine could not lock table 'tmp_SHAPE_Index' because it is already in use by another person or process."So I'm guessing the delete method on the IDataset interface doesn't do the job for a FC in Personal Geodatabase? What is the best way to delete a Personal Geodatabase feacture class? Thank you!Yukun
