AnsweredAssumed Answered
List Fields and Associated Domains--gets stuck on one table, why?
Question asked by MLF on Jun 14, 2012
Latest reply on Jun 19, 2012 by MLF
Hello!  This script combs the SDE's feature classes and tables and reports back which fields have domains applied and which domains they are.  It works beautifully, returning 553 records, until it hits a mystery table which our DBA created, called "DBASERVICE.TOAD_PLAN_TABLE."  I don't know what causes the error (see below the script).  I thought first that maybe the table had no fields, but SQLDev shows that it does--fields, but no data.  I need either to fix the issue, or write error-handling that will skip this table so that it will move on with the rest of the items in the SDE.  I don't know how to do either, so I'm hoping someone out there does!  Thanks!
HERE'S THE SCRIPT:
import arcpy
#Set workspace environment to geodatabase
arcpy.env.workspace = r"Database Connections\PROD_fakesrv1.SDE.sde"
#Get list of feature classes in geodatabase
FCs = arcpy.ListFeatureClasses()
#Loop through feature classes in list
for FC in FCs:
        #List fields in feature class
        fields = arcpy.ListFields(FC)
        #Loop through fields
        for field in fields:
            #Check if field has domain
            if field.domain != "":
                #Print feature class, field, domain name
                print FC, ",", field.name, ",", field.domain
#Get list of tables in geodatabase
TBs = arcpy.ListTables()
#Loop through tables in list
for TB in TBs:
        #List tables in feature dataset
        fields = arcpy.ListFields(TB)
                #Print table, field, domain name
                print TB, ",", field.name, ",", field.domain
HERE'S THE ERROR:
  File "U:\SDE_Domains\WhichDomainsAreInUseHereSDE.py", line 30, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\__init__.py", line 787, in ListFields
    return gp.listFields(*args)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 342, in listFields
    self._gp.ListFields(*gp_fixargs(args)))
IOError: DBASERVICE.TOAD_PLAN_TABLE
Outcomes
