Hello all -
I've discovered a strange inconsistency with customViewForGraphic in which every so often (about every six or seven calls,) the AGSGraphic parameter's attributes get whacked and using objectForKey: causes a crash with the following description:
*** -[CFString copyWithZone:]: message sent to deallocated instance 0xeda0de0
It always seems to happen when trying to access the one particular key only; i.e. accessing other attributes is successful. The attributes of all the graphics in this layer are never changed. The mapView:(AGSMapView *)mapView
didClickAtPoint:(CGPoint)screen method that is called immediately before the customViewForGraphic method gets passed a graphic object that contains the key of the attribute I am accessing, and produces no error when calling objectForKey:.
Thanks -
