Hello, I am attempting to loop through a process that will recalculate acres, select slivers and eliminate. However, when I recalculate acres after the first eliminate I get the following error message: Failed to execute. Parameters are not valid.ERROR 000732: Input Table: Dataset \\glarofas01\\elbows\\GreatLakes_NWI_Update\\MN\\EcognitionOutput\\Clip_Fix\\Elim\\Round1\\q3032sw does not exist or is not supportedFailed to execute (CalculateField).The file that I am trying to pass into the Calculate Field function does exist. Also, the process works when I do it in model builder and directly from the tool in ArcCatalog. Unfortunately, I have a large set of data to process and would like to automate it. Any help would be greatly appreciated.
outtemp = "C:\\Workspace\\crap\\outtemp"
outtempdat2 = "C:\\Workspace\\crap\\outtempdat2"
outtempdat3 = "C:\\Workspace\\crap\\outtempdat3"
for infile in qqlist:
eliminate_file = elim_path + infile
try_file = update_path + infile + "_singlepart.shp"
try:
gp.CalculateField_management(try_file, "ACRES", "!SHAPE.AREA@ACRES!", "PYTHON", "")
try:
if infile not in fail_list:
gp.MakeFeatureLayer_management(try_file,outtemp, )
gp.OverWriteOutput = 1
gp.SelectLayerByAttribute_management(outtemp, "NEW_SELECTION", "\"ACRES\" < 0.025 ")
# Process: While ther are sliver continue through loop...
if countdat > 0:
gp.Eliminate_management(outtemp, eliminate_file, "LENGTH", "", "")
gp.CalculateField_management(eliminate_file_2, "ACRES", "!SHAPE.AREA@ACRES!", "PYTHON", "")
gp.MakeFeatureLayer_management(eliminate_file,outtempdat2,)
gp.SelectLayerByAttribute_management(outtempdat2,"NEW_SELECTION", query)
countdat = gp.GetCount_management(outtempdat2)
elim_count = 0
if countdat == 0:
try:
os.system("copy \"%s\" \"%s\"" % (outtempdat2, output_path + infile))
except:
fail_list.append(infile)
i = 0
while countdat > 0:
eliminate_file = eliminate_file + str(countdat)
gp.CalculateField_management(eliminate_file, "ACRES", "!SHAPE.AREA@ACRES!", "PYTHON", "")
gp.MakeFeatureLayer_management(eliminate_file,outtempdat3,)
print gp.GetMessages(0)
gp.SelectLayerByAttribute_management(outtempdat3,"NEW_SELECTION", query)
countdat = gp.GetCount_management(outtempdat3)
elim_count = 0
if countdat == 0:
try:
os.system("copy \"%s\" \"%s\"" % (outtempdat3, output_path + infile))
except:
else:
if countdat == 0:
try:
os.system("copy \"%s\" \"%s\"" % (outtemp, output_path + infile))
except:
else:
except:
except:
