Zoom in Zoom out control
994
6
06-07-2012 10:26 PM
PramodHarithsa1
Occasional Contributor II
I have two external button for zoomin and zoom out.
on click of zoomin button i am using
map.centerAndZoom()
function.
But it doesnt work for me.
i want the extent to be maximixed and minimized..
when use this,
map.centerAndZoom((0,0),1)
map.centerAndZoom((0,0),2)
map centers to one position.. how do i make it dynamic..
i.e., on click on button it should keep zooming in.. and similarly the zoom out button as well
what other functions for the same can i manifest?
HemingZhu
Occasional Contributor III
map.centerAndZoom()
function.
when use this,
Try this:
For ZoomIn Button:
var extent=map.extent;
map.setExtent(extent.expand(0.5));
For ZoomOut Button:
map.setExtent(extent.expand(2));
derekswingley1
If you're using a tiled service, you can get the map's level, add or subtract one from it depending on which button is clicked and pass that as the second argument to centerAndZoom.
If you're not using a tiled service, centerAndZoom probably isn't what you want. Rather, try building a new extent and using map.setExtent. More info about using extents:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/intro_extents.htm
PramodHarithsa1
I have a tiled service layer as well as a DynamicMapServiceLayer in the map..
for the location attribute i tried something like (map.extent.xmin+map.extent.xmax)/2 and similarly for y parameter.. but it didn't work for me.
I just want the + and - functionality of zoom slider into buttons i have defined!
PramodHarithsa1
With Reference to the doc.,
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
How are the constants ZOOM_IN and ZOOM_OUT used?
HemingZhu
map.centerAndZoom()
function.
when use this,
Try this:
For ZoomIn Button:
For ZoomOut Button:
PramodHarithsa1
Try this:
For ZoomIn Button:
For ZoomOut Button:
Thanks a lot Zhu, That worked for me..
where can i get such methods described? I was looking here http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm
HemingZhu
Under API Reference Tab looking for Geometry -> Extent.
