arcpy.AddField_management(NewTrees, "Public", "TEXT", "", "", "", "", "", "REQUIRED", "Public")
Solved! Go to Solution.
Does anyone know why Python would add an underscore to a field name!?
# Replace a layer/table view name with a path to a dataset (which can be a layer file) or create the layer/table view within the script # The following inputs are layers or table views: "UTC_Parcels" arcpy.AddField_management("UTC_Parcels","Public","TEXT","#","#","#","#","NULLABLE","REQUIRED","#")
