Raste Calculator Error PLEASE HELP!!
3412
06-05-2012 06:10 AM
ElenaSava
I'm trying to calculate the following expression
             Con(IsNull(("%roadpct%")), 0,("%roadpct%" / 100))  / Float(Lookup("%roadpct%", "Count"))
but for some reason I get the error below. I have tried everything I just cannot seem to figure it out. PLEASE SOMEONE HELP!!! I'm sure its simple but I can't seem to find it.
ERROR 000539: Error running expression: rcexec() <class 'arcgisscripting.ExecuteError'>: ERROR 010414: Error in creating a Raster from a geodataset.
Failed to execute (Lookup).
Failed to execute (Raster Calculator (14)).
Thank you very much!!
MarkBoucher
Occasional Contributor III
Do you think the error could be due to the Lookup("roadpct","Count") trying to work on a raster that has Null values in it?
What if you
first cleared out the nulls using Con(IsNull(("roadpct")), 0,("roadpct")) and then performed ("roadpct" / 100) / Float(Lookup("roadpct", "Count")).
DanPatterson_Retired
ElenaSava
I have checked the input dataset and changed the output workspace. The error still appears =/
MarkBoucher
What if you
ElenaSava
Thank you very much for your help!!! I was able to figure it out. For some reason the model was not reading one of my shapefiles although I don't know why. Thanks again
