Hi all,
Just learning python script and was wondering if you could help me out. I've got a script that will be converting a KML to lyr and then appending it to a feature class in a file geodatabase.
import arcpy
arcpy.env.workspace = r"C:\Users\KJacobsen\Desktop\Griffiths\Griffiths.gdb"
#import GPS files
input = r"C:\Users\KJacobsen\Desktop\Griffiths\04232012_Documents\DATA from TEDEBAYE\garmin\120418 GARMIN\CCBJ.kmz"
outputFolder = r"C:\Users\KJacobsen\Desktop\Griffiths"
lyr = arcpy.KMLToLayer_conversion(input, outputFolder, "KML3")
FC = r"C:\Users\KJacobsen\Desktop\Griffiths\Griffiths.gdb\CHAMP"
arcpy.Append_management(lyr,FC,"NO_TEST")
I'm receiving the following error and am unsure of how to proceed...
Thanks in advance,
File "C:\Python26\ArcGIS10.0\lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 312, in RunScript
exec codeObject in __main__.__dict__
File "...\Desktop\ImportData.py", line 9, in <module>
File "...\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 2965, in Append
raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000349: The input parameter is not a Table View
Failed to execute (Append).
