I'm trying to display a Dynamic Map Service Layer over the Google streets map. I have been following the 'Adding an ArcGIS Server map to Google Maps' found in this tutorial. My dynamic service will not display. It works in every other web-map I've built using FLEX or Javascript API, but it will not display over the Google base layer. What am I missing?Live map - A big red dot should appear near the center showing the point layer I'm trying to pull in but it's not visible. That's the problem.Here's my code:<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
<head>
<title>Google Maps + ArcGIS</title>
<meta http-equiv="content-type" content="text/html; charset=UTF-8"/>
<script src="http://maps.google.com/maps?file=api&v=2&key=AIzaSyDDlcIQ61bcnNSaLKNoBaD6u09Yq1WuUb8" type="text/javascript"></script>
<script src="http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6" type="text/javascript" ></script>
<!-- Required for dijits -->
<script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
<!-- Add ESRI Javascript API -->
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
<!-- Add Jquery Library -->
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4.2/jquery.min.js"></script>
// Add Dojo elements
dojo.require("dijit.dijit");
dojo.require("dojo.parser");
dojo.require("dijit.layout.AccordionContainer");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.TitlePane");
dojo.require("esri.map");
dojo.require("esri.virtualearth.VETiledLayer");
dojo.require("esri.dijit.BasemapGallery");
dojo.require("esri.arcgis.utils");
dojo.require("esri.SnappingManager");
dojo.require("esri.dijit.Legend");
dojo.require("dijit.form.CheckBox");
dojo.require("esri.dijit.Measurement");
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.tasks.query");
dojo.require("esri.dijit.Popup");
var map;
var gmap = null;
function init_google() {
//Load Google Maps
gmap = new GMap2(document.getElementById("gmap"));
var centerat = new GLatLng(28, -82.5);
gmap.addControl(new GLargeMapControl());
gmap.addControl(new GMapTypeControl());
gmap.setCenter(centerat, 10);
gmap.enableScrollWheelZoom();
var dynamicMap = new esri.arcgis.gmaps.DynamicMapServiceLayer
("http://map.entrix.com/ArcGIS/rest/services/Misc/RiverviewOfficePointsWGS84/MapServer",
null, 1.0, function(overlay) {gmap.addOverlay(dynamicMap);}
</script>
</head>
<body onload="init_google();" onunload="GUnload();">
<div id="gmap" style="width: 500px; height:500px;"></div>
</body>
</html>
