bridgji
Get 500 error with json format getting layers
Discussion created by bridgji on May 24, 2012
When I call http://fmtvmarcgis10/ArcGIS/rest/services/DemoMap2/MapServer/layers?f=json against a map we have containing a geoprocessign service I wrote.
I get {"currentVersion":10.03,"error":{"code":500,"message":"An unexpected error occurred processing the request.","details":[]}}],"tables":[]}
If I chagne it to html format I'm getting the information i expect, I've pasted a sample at the end of the email.
The map this is occuring with has a geoprocessing service I've published  based on the sample in help which seems to publish fine and run as I expect in map.
I'm not sure why formating it as json vs html would cause it to fail.
I don't seem to see anything in the logs.
Jim
Layers:
Layer: BuffClip (ID: 0)
Display Field:
Type: Group Layer
Geometry Type:
Description:
Definition Expression:
Copyright Text:
Min. Scale: 0
Max. Scale: 0
Default Visibility: True
Extent:
XMin: 1315909.87892286
YMin: 282406.861164436
XMax: 1315918.98717237
YMax: 282415.880175278
Spatial Reference: 2285
Has Attachments: False
HTML Popup Type: esriServerHTMLPopupTypeNone
Fields:
Type ID Field: N/A
Layer: Parcels (ID: 2)
Display Field: Name
Type: Feature Layer
Outcomes
