Problem of template :glare analysis
434
05-23-2012 03:47 PM
LuLinCao
I want to use template glare analysis. I flow the GettingStarted_Glareanalysis do a excise.I failed and got the massage :Executing (Create Sun Skymap): SunSkymap Buildings "(UTC+8:00) Beijing, Hong Kong, Kuala Lampur, Singapore, Taipei, Ulaanbaatar" "2010-3-21 11:00:00" "2010-3-21 13:00:00" # 1 # true "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Sun" 7500 0
Start Time: Wed May 23 20:59:01 2012
Running script SunSkymap...
PYTHON ERRORS:
Traceback info:
  File "D:\Shadow\Maps and GDBs\Sun_tools\ClassSunSkyMap.py", line 258, in <module>
    timeList = Times().Times
Error Info:
time data '2010-3-21 11:00:00' does not match format '%m/%d/%Y %H:%M:%S'
ArcPy ERRORS:
Completed script SunSkymap...
Failed to execute (Create Sun Skymap).
Failed at Wed May 23 20:59:01 2012 (Elapsed Time: 0.00 seconds)
Executing (Skyline): Skyline "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Sun" "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Silhouettes" # "1000 Meters" "0 Meters" Buildings FULL_DETAIL 0 360 1 "0 Meters" NO_SEGMENT_SKYLINE 100 VERTICAL_ANGLE SKYLINE_MAXIMUM NO_CURVATURE NO_REFRACTION .13 0 NO_CREATE_SILHOUETTES
All the inputs are not current.
Succeeded at Wed May 23 20:59:01 2012 (Elapsed Time: 0.00 seconds)
Executing (Skyline Barrier): SkylineBarrier "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Sun" "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Silhouettes" "D:\Shadow\Maps and GDBs\Shadows.gdb\Buildings_Shadows" # # CLOSED "0 Meters" PROJECT_TO_PLANE
I know tha the time date format is wrong but I can not use the wright format as input. Could someone tell how to do it. Thank you very much!
