map algebra expression / raster calculator arcmap10
3442
05-23-2012 03:56 AM
MaximilianSesselmann
hey folks,
i???ve got a problem concerning the raster-calculator-tool in arcmap 10. I hope someone can help me. excuse my poor english skills???
the situation:
- i model drainage-systems based on high-resolution lidar-dgm (1m).
- i want to thin-out the flow-accumulation-tool results
- therefore I want to eliminate all streams that have less then 50 cells and have no upstream connection (last are called 1st-order streams)
- i created a stream-link-raster (it tells the lenght of segment in the attribute-table-field COUNT) and a stream-order-raster (it gives each segment an order-number beginning with 1) [both tools are available in spatial analyst ??? hydrology-toolset]
- now i need a single-output-map-algebra-expression that says:
???if the stream order is 1 and the stream segment has 50 cells or less, then turn the cell into NoData. Otherwise, return the stream link ID.???
i tried to solve this problem using the raster calculator.
first things first: i???m absolutely not a pro in skripting/programming! Not even at this simple level???
i'm sure its only a little mistake, but i can???t find it by myself.
my code looks like this:
SetNull("str_ord_klein"  == 1  &  "StreamLink".COUNT <= 50, "StreamLink")
"str_ord_klein"  is the stream-order-raster
"StreamLink" is the stream-link-raster
the process starts but it is cancelled immediately saying this:
Executing: RasterCalculator SetNull("str_ord_klein"  == 1  &  "StreamLink".COUNT   <  50, "StreamLink") "D:\Daten\Studium\DIPLOMARBEIT\GIS\Hydrologie Modellierung\Rasterdaten\STREAM EDITED\stream_thinned"
Start Time: Wed May 23 13:35:00 2012
SetNull(Raster(r"str_ord_klein")  == 1  &  Raster(r"StreamLink").COUNT   <  50, Raster(r"StreamLink"))
ERROR 000539: Error running expression: rcexec() <type 'exceptions.AttributeError'>: 'Raster' object has no attribute 'COUNT'
Failed to execute (RasterCalculator).
Failed at Wed May 23 13:35:00 2012 (Elapsed Time: 0,00 seconds)
i would be very happy and grateful if someone could help me.
kind regards,
max
TimothyHales
Esri Notable Contributor
You cannot use dot notation in ArcGIS 10.  You will need to use the Lookup function.  Something like this:
SetNull(("StreamOrder"==1)  & ( Lookup("StreamLink","count") <= 50), "StreamLink")
Using raster attribute other than 'value' in map algebra
Lookup function in v10.0 Map Algebra: implementing dot notation in v10.0?
What is wrong with this syntax when using the ???raster calculator????
TimothyHales
this one worked out well! thanks
