Hi, I used SelectByLocation geoprocessing object in c#.
selByLocation.in_layer = lyConvexLine;
selByLocation.select_features = lyConevex;
selByLocation.overlap_type = "INTERSECT";
gp.Execute(selByLocation, null);
selByLocation.select_features = lyPairLine;
selByLocation.overlap_type = "WITHIN";
selByLocation.selection_type = "REMOVE_FROM_SELECTION";
above code worked well. However, in other part of same code, SelectByLocation did not work at all.
selByLocation.in_layer = lySelectedPoints;
selByLocation.select_features = lyTempPair;
selByLocation.overlap_type = "ARE_IDENTICAL_TO";
After above part, nothing happend. I checked number of selected object by GetCount, and even CopyFeature tool, but nothing was selected. THe only difference 1st and 2nd code is: at 1st code, layers were polygon and line, at 2nd all of two layers were points. But SelectByLocation meant to be worked well with point as well, right? I test other overlap_types... all of them failed. My features are not broken. I checked those features inputted to selectByLocation manually.
