Hello,I am working on running through an SDE database, and renaming a few hundred point feature classes using arcpy.Rename_management(). I use ListFeatureClasses to find the files, and once I hit the ones I want to rename, I use a searchcursor to use a field to rename.When I get to the part in my script where I use this, the script seems to freeze, and I was wondering if SDE feature classes support this? I ran it on a file gdb, and everything worked fine ...
import arcpy
from arcpy import env
def updateName():
arcpy.env.workspace = raw_input("Enter path of database: ")
for tab in arcpy.ListFeatureClasses("","Point",""):
desc = arcpy.Describe(tab)
newName = ""
if desc.datasetType == 'RasterDataset':
print "Skipping raster "+tab
if desc.datasetType == 'FeatureClass':
print "Searching "+desc.datasetType+": "+tab
for row in arcpy.SearchCursor(tab):
newName = "StandID_"+str(row.StandID)+"_Pt"
print " Updating "+tab+" to "+newName+"..."
arcpy.Rename_management(tab, newName)
break
updateName()
print "\nUpdate complete for "+arcpy.env.workspace+"."
