jbays6832
Copy selected records does not paste into Excel
Discussion created by jbays6832 on May 22, 2012
Latest reply on May 22, 2012 by mzcoyle
When I select records from an attribute table and then select "copy selected" and then try to paste the copied records into excel, several columns are not included. For example if the records I copy contain Column A, B, C, D, E, and F, when I paste the selected records into excel, Column B and E are not pasted into excel, even though they should have been copied. There is no blank space where they should be, the following columns just fill in the gaps. Any idea what is causing this/ how I can ensure that all data I copy from an attribute table will be pasted in Excel?
Outcomes
