I am trying to achieve a convex hull over a feature Set returned by a query. But have been facing the error below which i am not able to figure outIn order to debug to see how the convex hull works i had mocked up features and ran the convex hull for the created poly line features as seen in the below code. This works fine, But the above approach of plotting a convexhull for the feature set fails with the below error.Error:1) OPTIONS file:///C:/wip/maps/code/test/proxy.ashx?http://karthikpc:8399/arcgis/rest/services/Geometry/GeometryServer/convexHull Resource failed to load 2) Another is a type error TypeErrorarguments: Array[2]get message: function () { [native code] }get stack: function () { [native code] }set message: function () { [native code] }set stack: function () { [native code] }type: "non_object_property_load"__proto__: ErrorHave given my function below. function bounding_polygon(featureSet){
var geometries = [];
var geometries_1 = [];
var geoms=[];
var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0,0.85]), 2);
//getting geometry from feature set
var geoms = dojo.map(featureSet.features, function(graphic) {
return graphic.geometry;
map.graphics.clear();
//function that fails
gsvc.convexHull(geoms,function store_value(result){
var symbol;
switch(result.type){
case "point":
symbol = new esri.symbol.SimpleMarkerSymbol();
break;
case "polyline":
symbol = new esri.symbol.SimpleLineSymbol();
break;
case "polygon":
symbol = new esri.symbol.SimpleFillSymbol();
break;
map.graphics.add(new esri.Graphic(result,symbol));
},function error_log(error){});
//trying to run the same for manually created geometries
var new_polyline= new esri.geometry.Polyline(map.spatialReference);
var other_polyline= new esri.geometry.Polyline(map.spatialReference);
new_polyline.addPath([[103.76794615402221, 1.4416487206261546], [103.76790721700029, 1.4427548269642734], [103.76789991705209, 1.4429139656905441]]);
other_polyline.addPath([[103.77897404312868, 1.3687951231704805], [103.7789286010334, 1.36900185852713], [103.7788202535522, 1.3694226417416273]]);
geometries_1[0]=new_polyline;
geometries_1[1]=other_polyline;
gsvc.convexHull(geometries_1,function store_value(result){
var symbol;
case "point":
break;
case "polyline":
break;
case "polygon":
break;
Let me know if i would need to clarify more on this.
