System ArcGIS 9.3Problem:I want to make join based on a field C**** (C3438 or C9123).However, I do not know how to describe the field for the gp.joinfield code as below.(python also show it as a syntax error.)Please kindly help and thank you.##Script Name: latitude of north or south limit
##Description: Extract latitude of north and south boundary of B or NB range size
##Created By: Elaine Kuo
##Date: 12/05/2012
#Import standard library modules
import arcgisscripting
import os
#Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
#Set the input workspace
#GP.workspace = sys.argv[1]
#Set the workspace.
gp.Workspace= "H:/temp/test1"
#Set the output workspace
#outWorkspace = sys.argv[2]
#Set the workspace. List all of the feature classes in the dataset
outWorkspace= "H:/temp"
#Get a list of the featureclasses in the input folder
fcs = gp.ListFeatureClasses()
# Loop through every item in the list that was just generated
for fc in fcs:
# Break out the name, no path or extension, using the describe object.
desc = gp.describe(fc)
featureName = desc.name
# Add a field to this shapefile, of type LONG
gp.AddField (fc, "NorthLat", "double", 6,6)
gp.AddField (fc, "SouthLat", "double", 6,6)
# Get a list of the fields in the featureclass
fields = gp.ListFields(fc, "C*", "String")
for field in fields:
gp.toolbox = "Data Management"
gp.addMessage(type(field))
# Select records to be deleted (C*, i.e. C7658)
# Make temporary featureclasses
query = "\"%s\" = 'S'" % field.Name
gp.Select_analysis(fc,("output.shp"),query)
# get latitude of north and south limits
ext = gp.describe("output.shp").extent
NorthLat = ext.YMax
SouthLat = ext.YMin
gp.CalculateField_management("output.shp", "NorthLat",str(NorthLat))
gp.CalculateField_management("output.shp", "SouthLat",str(SouthLat))
#Validate the new feature class name for the output workspace.
outFeatureClass = outWorkspace + os.sep +gp.ValidateTableName(fc,outWorkspace)
# copy temporary shapefile to fc
gp.CopyFeatures("output.shp", outFeatureClass)
gp.joinfield (fc, \"%s\", outFeatureClass, \"%s\")
# clear memory of temporary shapefile
gp.Delete("output.shp")
gp.AddMessage(gp.GetMessages())
print gp.GetMessages()
