# Import arcpy module import arcpy import string import os # Local variables: #Set workspace arcpy.env.workspace = "C:\\DWG\\FOLDER\\FOLDER*" Polyline = "\Polyline" LineShp = "C:\\DWG\\FOLDER\\Shape\\" # Process: Select for i in arcpy.ListFiles ("*.dwg"): x = i.strip('.dwgDWG') fileout = LineShp + x + ".shp" print "Processing:" + arcpy.env.workspace + "\\" + Polyline + "To:" + fileout
Try posting your entire code. All I see it doing is print this line for every iteration of your loop
By no means is this answer going to be complete, but when specifying a file location (as in C:\DWG.....) you only need to use the double backslash after the C:\\ - so it would look like "C:\\DWG\...." or you can use single forward (/) slashes instead, which admittedly is annoying if you are doing a copy/paste of an address. another way to reference file paths is to put an r in front of it, so like: r"C:\DWG\... ["/QUOTE]
Thanks for reminding me of this. I had forgotten.RPI_Bryan;199036 wrote:
There is a free online course you can take for python in the training section.
I did this about 2 years ago but I should probably run through it again.
import arcpy, os from arcpy import env env.workspace = r"C:\temp\python" for (path, dirs, files) in os.walk(env.workspace): for file in files: # find all DWG files in folder and all subfolders if ".dwg" in file.lower()[-4:]: dwg_path = os.path.join(path, file) + "\Polyline" # set the MXD mxd = arcpy.mapping.MapDocument("CURRENT") # set the Dataframe df = arcpy.mapping.ListDataFrames(mxd,"*")[0] # create a new layer newlayer = arcpy.mapping.Layer(dwg_path) # add the layer to the map arcpy.mapping.AddLayer(df, newlayer,"AUTO_ARRANGE") del mxd
