jmjohnston
Intersecting lines returns no records
Discussion created by jmjohnston on May 14, 2012
Latest reply on Jun 27, 2012 by dlee-esristaff
I'm trying to use the intersect function to combine attributes of overlapping line features. This has always worked in the past and it's pretty simple; put the attributes from the intersected feature onto the transect line that crosses it. These features clearly cross each other but the output returns no new features while adding all the fields from both to an empty set.
I've attached a sample with two lines that intersect. Doe this function just not work in ArcGIS10 or am I doing something wrong?
Outcomes
