The display names for the application tabs are coming from the Workflow Manager DLLs so changing it inside the JTXUIConfig.xml file will not alter the values. You can create your own specific tabs and add the display names to the config file as you want it to appear. Extended properties and linked properties tab names can be modified on a "per job" basis. Also, the view title job and reports can also be modified inside the config file. Thanks,Tope
