I have two of the samples working great! One that customizes the popup and the other that has a nice layout with legend. I can't for the life of me seem to combine them to make one great website.
I think the problem has to do with the first one uses a feature map service and the second a dynamic map service?
Below is the code I'm using. I get no map, no legend and no pop-up.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/esri/dijit/css/Popup.css"/> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; } body{ background-color:white; overflow:hidden; font-family: "Trebuchet MS"; } #header { background-image: url(images/banner.jpg); background-repeat: repeat-x; margin: 2px; border: solid 4px #224a54; color:white; font-size:18pt; text-align:left; font-weight:bold; height:66px; } #subheader { font-size:20pt; color:white; padding-left:2px; } #rightPane{ background-color:white; color:#3f3f3f; border: solid 2px #224a54; width:20%; } #leftPane{ margin: 1px; padding:2px; background-color:white; color:#3f3f3f; border: solid 2px #224a54; width:20%; } #map { margin: 5px; border:solid 4px #224a54; -moz-border-radius: 1px; } #footer { margin: 2px; border: solid 2px #224a54; background-color:#ecefe4;color:#3f3f3f; font-size:10pt; text-align:center; height:20px; } .dijitTabInnerDiv{ background-color:#ecefe4; } #tabs{ padding:5px; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"> </script> <script type="text/javascript"> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("dijit.layout.TabContainer"); dojo.require("esri.dijit.Legend"); dojo.require("esri.dijit.InfoWindow"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.Popup"); var map; function init() { esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var initialExtent = new esri.geometry.Extent({"xmin":-13440283.392,"ymin":4195625.999,"xmax":-13424995.986,"ymax":4207091.553,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: initialExtent }); //define custom popup options var popupOptions = { 'markerSymbol': new esri.symbol.SimpleMarkerSymbol('circle', 32, null, new dojo.Color([0, 0, 0, 0.25])), 'marginLeft': '20', 'marginTop': '20' }; //create a popup to replace the map's info window var popup = new esri.dijit.Popup(popupOptions, dojo.create("div")); map = new esri.Map("map", { extent: initExtent, infoWindow: popup }); dojo.connect(map, 'onLoad', function(map) { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); var basemapUrl = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"; var dynamicUrl = "http://mapserver/ArcGIS/rest/services/online/CIP/MapServer"; var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl); var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dynamicUrl); //define a popup template var popupTemplate = new esri.dijit.PopupTemplate({ title: "CIP Project Info", fieldInfos: [ {fieldName: "JOBNAME", visible: true, label:"ID"}, {fieldName: "DESC", visible:true, label:"Description"}, {fieldName: "START", visible:true, label:"Start Date" ,format:{dateFormat:'shortDateShortTime'}} ], showAttachments:true }); //create a feature layer based on the feature collection var featureLayer = new esri.layers.FeatureLayer("http://mapserver/ArcGIS/rest/services/online/CIP/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, infoTemplate: popupTemplate, outFields: ['JOBNAME',"DESC","START",'TYPE'] }); featureLayer.setDefinitionExpression("TYPE != ''"); dojo.connect(featureLayer,"onClick",function(evt){ map.infoWindow.setFeatures([evt.graphic]); }); dojo.connect(map,'onLayersAddResult',function(results){ //add the legend var legend = new esri.dijit.Legend({ map:map, layerInfos:[{layer:dynamicLayer,title:"Measure Y Hard at Work"}], arrangement:esri.dijit.Legend.ALIGN_RIGHT },"legendDiv"); legend.startup(); }); map.addLayer(basemap); map.addLayers([dynamicLayer]); map.addLayer(featureLayer); }
//show map on load dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%; height:100%;"> <div id="header" dojotype="dijit.layout.ContentPane" region="top"> City of San Luis Obispo <div id="subheader">Capital Improvement Projects</div> </div> <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left"> <div dojotype="dijit.layout.TabContainer" > <div dojotype="dijit.layout.ContentPane" title = "Legend" selected="true"> <div id="legendDiv"></div> </div> </div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center"> </div> <div id="footer" dojotype="dijit.layout.ContentPane" region="bottom" > <b>Measure Y Hard at Work!</b> A significant number of improvement projects are made possible by the 1/2 Cent tax approved by city voters in 2006. <a href="http://www.slocity.org/publicworks/construction/measurey.asp" target="_blank">Visit our Measure Y page</a> </div> </div> </body>
My I would like to help but I'm having a little trouble because there is a lot going on.
First this example link generic - http://help.arcgis.com/en/webapi/jav...ples_start.htm 2. You should wrap your code with the code tool or like so it is easier to read 3. Your url is not public http://mapserver/ArcGIS/rest/services/online/CIP/MapServer so that could be a problem. 4. If your url is internal it is kind of strange to have "online" after services and before your mapserver name "CIP" - I would check this address and the feature layer address 5. in the line of code map.addLayers([dynamicLayer]); - I would try to drop the []
extent: initExtent,
infoWindow: popup
The map and legend are now showing up!!! We are moving in the right direction!
However the pop-ups are not working. Any ideas?
Jay- My service is not yet public, it's on a development server but I'll move it when I have everything working. Thanks for the tip about wrapping code! Sorry about the link, it's just the popup up example in the widgets area on the JavaScript samples area.
I have also tried another approach, which I'll post in separately. I can get the legend to work or the pop-up but not both 😞
