bryankaraffa
FindTask reporting "unable to complete operation"
Discussion created by bryankaraffa on May 7, 2012
Latest reply on May 7, 2012 by bryankaraffa
Hi all,
I am trying to figure out what is wrong with my FindTask script.. I used a sample and made changed 2 lines where appropriate and it is not working as intended.....  I really am at a dead end here and was hoping for your help..
Ultimately, I'd like to be able to type "ANTH 121" or any other class in the field and have it return the values as it should but I just get the error "Error: Unable to complete  operation."
My code:
[HTML]<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Find</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.find");
      var find, params;
      function init() {
        find = new esri.tasks.FindTask("http://ags2.geog.ucsb.edu/ArcGIS/rest/services/bldgRoomLocator2012May07/MapServer");
        params = new esri.tasks.FindParameters();
        params.layerIds = [1];
        params.searchFields = ["courseTitle","fullTitle"];
      function doFind() {
        params.searchText = dojo.byId("searchText").value;
        find.execute(params, showResults, alert);
      function showResults(results) {
        var result, attribs;
        var s = ["<table border=\"1\"><thead><tr style=\"background-color:#ccc;\"><td>Course Title</td><td>Full Title</td><td>Primary Title</td><td>Location</td></tr></thead><tbody id=\"states\">"];
        dojo.forEach(results,function(result){
          attribs = result.feature.attributes;
           s.push("<tr><td>" + attribs.courseTitle + "</td><td>" + attribs.fullTitle + "</td><td>" + attribs.primaryTitle + "</td><td>" + attribs.location + "</td></tr>");
        s.push("</tbody></table>");
        dojo.byId("tbl").innerHTML = s.join("");
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    Search by Course Title: <input type="text" id="searchText" size="40" value="ANTH 121" />
    <input type="button" value="Find" onclick="doFind()" />
    <div id="tbl"></div>
  </body>
</html>[/HTML]
Outcomes
