helenak
CopyFeatures does not work in SelectLayerByAttribute
Discussion created by helenak on May 7, 2012
Latest reply on May 9, 2012 by helenak
System: ArcGIS 9.3
PythonWin: 2.5.1
Problem:
CopyFeatures was used in the code below, but the output featureclass was not copied to the workplace.
Please kindly help and thanks a lot.
##Script Name: Delete rows
##Description: delete selected rows
##Created By: Elaine Kuo
##Date: 08/05/2012
#Import standard library modules
import arcgisscripting
import os
#Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
#Set the input workspace
#GP.workspace = sys.argv[1]
#Set the workspace.
gp.Workspace= "G:/temp"
#Set the output workspace
#outWorkspace = sys.argv[2]
#Set the workspace. List all of the feature classes in the dataset
outWorkspace= "G:/temp/test"
#Get a list of the featureclasses in the input folder
fcs = gp.ListFeatureClasses()
# Loop through every item in the list that was just generated
for fc in fcs:
    # Break out the name, no path or extension, using the describe object.
    desc = gp.describe(fc)
    featureName = desc.name
    # Make featureclasses as layers
    gp.OverWriteOutput = 1
    gp.toolbox = "Data Management"
    gp.MakeFeatureLayer("geor0313_p.shp","geor0313_p_lyr")
    #Get a list of the fields in the featureclass
    fields = gp.ListFields("geor0313_p_lyr", "C*", "String")
    for field in fields:
        gp.addMessage(type(field))
        # Select records to be deleted (C*, i.e. C7658)
        query = "\"%s\" = 'R'" % field.Name
        gp.SelectLayerByAttribute("geor0313_p_lyr", "ADD_TO_SELECTION", query)
        # Delete selected records
        gp.DeleteRows("geor0313_p_lyr")
    #Validate the new feature class name for the output workspace.
    outFeatureClass = outWorkspace + os.sep +gp.ValidateTableName("geor0313_p_lyr",outWorkspace)
    # Write the selected features to a new featureclass
    gp.CopyFeatures("geor0313_p_lyr", outFeatureClass)
Outcomes
