Solved! Go to Solution.
import arcpy, os inputPath = some path outputPath = some other path #Loop through each MXD file for filename in os.listdir(inputPath): fullpath = os.path.join(inputPath, filename) if os.path.isfile(fullpath): if filename.lower().endswith(".mxd"): #Reference MXD and export mxd = arcpy.mapping.MapDocument(fullpath) arcpy.mapping.ExportToJPEG(mxd, outputPath + "\\" + filename + ".jpg")
import arcpy, os inputPath = os.curdir outputPath = os.curdir #Loop through each MXD file for filename in os.listdir(inputPath): fullpath = os.path.join(inputPath, filename) if os.path.isfile(fullpath): if filename.lower().endswith(".mxd"): #Reference MXD and export mxd = arcpy.mapping.MapDocument(fullpath) OutputJPGPath = os.path.join(outputPath, filename.replace(".mxd", ".jpg")) #arcpy.mapping.ExportToJPEG(mxd, OutputJPGPath) arcpy.mapping.ExportToJPEG(mxd, OutputJPGPath, 'PAGE_LAYOUT', 0, 0, 200, "False", '24-BIT_TRUE_COLOR', 100)
