robertlindquist
display of multiple maptips
Discussion created by robertlindquist on May 3, 2012
I have a point feature class for which I use map tips to display an attribute.  In some places, there are multiple points located close to one another.  When zoomed in to say 1:10,000 the points are far enough apart that each individual map tip displays.  However, when zoomed out much past 1:10,000 one map tip displays -- apparently the tip for the first found point.  I'd like to be able to display the maptips for all points; perhaps as a stacked set.  Is there an easy way to accomplish this?
Or, do I need to write some code to select points within some cluster and then display the map tips?
Any suggestions would be greatly appreciated.
Outcomes
