Problem in passing mappoint to geoprocessing task via flex application
654
05-05-2010 09:59 PM
DeepikaSingh
This is sample watershed geoprocessing task,which takes input from user as mappoint which is named as pourpoint in task.when i supply input interactively from Arcmap it runs successfully but when i tried to supply that pourpoint from my Flex application it gives error.
the geometry of mappoint is:
event.graphic.geometry.toString()=MapPoint[x=483296.9432867807,y=219407.33375396187,wkid=32145]
but it gives fault of invalid value for pourpoint.
CODE:
private function drawEndHandler(event:DrawEvent):void
             Alert.show(event.graphic.geometry.toString());
         var featureSet:FeatureSet = new FeatureSet([event.graphic.geometry]);
         var params:Object = new Object();
         params.pourpoint=featureSet;
         var geoprocessTask:Geoprocessor = new Geoprocessor();
             geoprocessTask.url = "http://wksnt13/ArcGIS/rest/services/Stowe/GPServer/CreateWatershedPolygonModel";
                geoprocessTask.submitJob(params);
                geoprocessTask.addEventListener(GeoprocessorEvent.JOB_COMPLETE,jobCompleteHandler);
                geoprocessTask.addEventListener(FaultEvent.FAULT, faultHandler);
            private function jobCompleteHandler(e:GeoprocessorEvent):void
             Alert.show("1234");
            private function faultHandler(f:FaultEvent):void
                Alert.show("Unexpected fault:\n" + f.toString());
ERROR:
Unexpected fault:
[FaultEvent fault=[RPC Fault faultString="" faultCode="400" faultDetail="Invalid value for parameter '<i>pourpoint</i>'"] messageId=null type="fault" bubbles=false cancelable=true eventPhase=2]
DasaPaddock
Try creating your FeatureSet like this:
var featureSet:FeatureSet = new FeatureSet([event.graphic]);
or this
var featureSet:FeatureSet = new FeatureSet([ { geometry: event.graphic.geometry } ]);
