Solved! Go to Solution.
###------------------------------ #Import standard library modules <- use arcgisscripting instead of win32com.client import arcgisscripting, sys, os #Create the Geoprocessor object GP = arcgisscripting.create(9.3) # use arcgisscripting.create() if your Arc is < 9.3 #Set the workspace. GP.Workspace= r"C:\test" GP.Toolbox = "Data Management" # <- should not have to be loaded try: #Get a list of the featureclasses in the input folder fcs = GP.ListFeatureClasses() for fc in fcs: # <- fcs is a list, not a cursor, so you do not use .next() # Add X Y coordinate to the feature classes GP.AddXY_management(fc) except: GP.AddMessage(GP.GetMessages(2)) print GP.GetMessages(2)
