AnsweredAssumed Answered
Problems refreshing map - VB.net Editor Extension
Question asked by rwinfrey on Apr 26, 2012
Latest reply on May 3, 2012 by kenbuja
I can't seem to find anyone else with this problem, but I'm hoping maybe I'm missing something obvious!
I am writing an Editor Extension add-in using VB.net for ArcMap 10.
Once the user starts editing, I use a unique value renderer to display features, omitting some (the client wants features they have classified as 'inactive' to disappear - without being deleted - and my understanding is that a definition query won't work in an edit session, so I have modified the symbology instead).
After I set the renderer, I want the display to refresh to show the new symbology.  However, ActiveView.Refresh, ActiveView.PartialRefresh, and ScreenDisplay.Invalidate will not work.  There is no error, but the screen does not refresh.  I have stepped through using the debugger and confirmed that the program execution does reach those lines, but after 'executing' those lines nothing happens.  The TOC updates properly, but the view does not.  I can manually click the refresh button and it refreshes just fine, but I can't seem to make it work programmatically.
I have tried brute forcing it by using ActiveView.Deactivate followed by ActiveView.Activate, and this does cause a screen refresh, but then when I try to draw the point, the mouse pointer and the marker symbol indicating the potential location of the new point are offset by about 4 inches.
I'm completely at a loss here.  Any ideas?
I've included an exerpt from my code below (this is done nearly identically for 4 feature layers, so normally the select case would have 3 more entries, but I simplified it for this post).  Thanks!!
        'define the colors to use in the renderers
        Dim pOutlineColor As New ESRI.ArcGIS.Display.RgbColor
        Dim pStructureColor As New ESRI.ArcGIS.Display.RgbColor
        'make the structure outline color black
pOutlineColor.Red = 0
pOutlineColor.Blue = 0
pOutlineColor.Green= 0
'make the structure center color macaw green
pStructureColor.Red = 152
pStructureColor.Blue = 0
        pStructureColor.Green = 230
        'create the symbols
        Dim pStructureSymbol As New ESRI.ArcGIS.Display.SimpleMarkerSymbol
        'construct the structures symbol
        pStructureSymbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCircle
        pStructureSymbol.Size = 4
        pStructureSymbol.Outline = True
        pStructureSymbol.OutlineSize = 1
        pStructureSymbol.OutlineColor = pOutlineColor
        pStructureSymbol.Color = pStructureColor
        'define renderers
        Dim pStructureRenderer As New ESRI.ArcGIS.Carto.UniqueValueRenderer
        'set the fields used in the renderers - we'll just have one, the 'Active' field
        'set usedefaultsymbol to false so that inactive features
        'will not draw (i.e., if Active <> 1 or Null)
        'structures renderer
        With pStructureRenderer
            .FieldCount = 1
            .Field(0) = "Active"
            .UseDefaultSymbol = False
            'add "1" to the value list for the renderer - i.e., display "1" values using pStructureSymbol
            .AddValue("1", "Active", pStructureSymbol)
            .Label("1") = "Active"
            'add "<Null>" to the value list for the renderer using the same symbology as "1"
            .AddReferenceValue("<Null>", "1")
            'tell it we're using our own custom style
            .ColorScheme = "Custom"
            'tell it the field type for the 'Active' field is not a string (it's an integer)
            .FieldType(0) = False
        End With
        Dim pLayer As ESRI.ArcGIS.Carto.ILayer
        Dim pFeatureLayer As ESRI.ArcGIS.Carto.IFeatureLayer2
        Dim pGeoFeatureLayerStructures As ESRI.ArcGIS.Carto.IGeoFeatureLayer
        'this makes the layer properties symbology tab show
        'the correct interface.
        Dim pPropertyPage As ESRI.ArcGIS.CartoUI.IRendererPropertyPage
        pPropertyPage = New ESRI.ArcGIS.CartoUI.UniqueValuePropertyPage
        Do Until pLayer Is Nothing
            If TypeOf (pLayer) Is ESRI.ArcGIS.Carto.IFeatureLayer2 Then
                pFeatureLayer = pLayer
                If pFeatureLayer.FeatureClass.FindField("Active") > 0 Then 'only set the renderer if there is an 'active' field in the layer
                    Select Case pFeatureLayer.FeatureClass.AliasName
                        Case strStructuresLayerName
                            pGeoFeatureLayerStructures = pFeatureLayer
                            pGeoFeatureLayerStructures.Renderer = pStructureRenderer
                            pGeoFeatureLayerStructures.DisplayField = "Active"
                            pGeoFeatureLayerStructures.RendererPropertyPageClassID = pPropertyPage.ClassID
                    End Select
                End If
                pFeatureLayer = Nothing
            End If
            pLayer = pEnumLayers.Next
        Loop
        My.Document.ActiveView.ContentsChanged()
        My.Document.UpdateContents()
        My.Document.ActiveView.Refresh() 'this does nothing
        'This also does nothing:
        'My.Document.ActiveView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewAll, Nothing, pActiveView.Extent)
        'My.ThisApplication.Display.Invalidate(My.Document.ActiveView.Extent, False, ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache)
        'this makes the screen go blank:
        'Dim pMaps As ESRI.ArcGIS.Carto.IMaps
'pMaps = My.Document.Maps
'My.Document.ActiveView = My.Document.PageLayout
        'My.Document.ActiveView = pMaps.Item(0)
        'My.Document.ActiveView.Refresh()
        'this makes the cursor and the point to be drawn offset by about 4 inches:
        'Dim pActiveView As ESRI.ArcGIS.Carto.IActiveView
        'pActiveView = My.Document.FocusMap
        'pActiveView.Deactivate()
        'pActiveView.Activate(My.ThisApplication.Display.hWnd)
Outcomes
