Zaldan
Access scope of front side before comp split?
Discussion created by Zaldan on Apr 24, 2012
Latest reply on Apr 26, 2012 by MBuehler-esristaff
Hi Matthias!
I have a question that has to do with models built on sloped lots.
Following your example, I started with the base volume:
Lot -->
 alignScopeToAxes(y)
 LotAligned(scope.sy)
LotAligned(yDim) -->
 alignScopeToAxes(y)
 extrude(world.y, 100)
 split(y) {yDim : BaseVolume | ~1 : NIL}
Then I want to do something to the top only if the front face exceeds a certain y scope. But I don't know how to access the y scope of the just the front without doing a component split first, and then I can't apply this to the top face, which is already split off.
Any suggestions?
Thanks!
-Marie
PS. One related question: I was trying to deal with this by setting a boolean attribute, i.e:
BaseVolume-->
 comp(f) {front: BaseFacade | left : BaseSide | right : BaseSide| back : BaseSide | bottom : NIL | top : setPivot (yzx,4) Ground Row }
BaseFacade  -->
 case scope.sy >= floorHeight: set(multistory, true)
 else:  BaseSide
However, this doesn't work. Any ideas?
Thank you...
Outcomes
