import arcpy, os # Local variables oldSDE = r"M:\Clients\M-O\ABC\_ArcGIS\2012\06\TestingRepath\SQL01\\" newSDE = r"M:\Clients\M-O\ABC\_ArcGIS\2012\06\TestingRepath\SQL02\\" mapDoc = r"M:\Clients\M-O\ABC\_ArcGIS\2012\06\TestingRepath\_Map02_wBackgrounds.mxd" print "Define MapDocument Parameter" mxd = arcpy.mapping.MapDocument(mapDoc) print "Start FindAndReplace Process" mxd.findAndReplaceWorkspacePaths(oldSDE, newSDE) print "Start saveAcopy Process" mxd.saveACopy(r"M:\Clients\M-O\ABC\_ArcGIS\2012\06\TestingRepath\_Map02_NEW_TenOne.mxd") print "Done" del arcpy, oldSDE, newSDE, mapDoc, mxd
