Adding callout (InfoTemplateDelegate) results in crash
1115
9
04-17-2012 06:35 AM
ReneNijkamp
Hi all,
I'm adding some graphics manually to the map, with the following code:
        double lat = [(NSNumber *) [colleague objectForKey: @"Latitude"] doubleValue];
        double lon = [(NSNumber *) [colleague objectForKey: @"Longitude"] doubleValue];
        if ( !(lat == 0.00 && lon == 0.00))
            AGSSimpleMarkerSymbol *pointMarker = [AGSSimpleMarkerSymbol simpleMarkerSymbolWithColor:[UIColor orangeColor]];
            pointMarker.size = 15; //[(NSNumber *) [colleague objectForKey: @"Precision"] intValue];
            pointMarker.style = AGSSimpleMarkerSymbolStyleCircle;
            AGSPoint *wgspoint = [AGSPoint pointWithX:lon y:lat spatialReference:[AGSSpatialReference spatialReferenceWithWKID:4326]];
            AGSGeometry *mapPoint = [_geometryEngine projectGeometry:wgspoint toSpatialReference:self.mapView.spatialReference];
//            LocationInfoTemplate * template = [[LocationInfoTemplate alloc] init];
            AGSCalloutTemplate* template = [[AGSCalloutTemplate alloc] init] ;
            template.titleTemplate = @"${Username}";
            template.detailTemplate = @"${TimeStamp}";
            AGSGraphic *location = [[AGSGraphic alloc] initWithGeometry: mapPoint
        symbol: pointMarker
                                                             attributes: [colleague mutableCopy]
                                                   infoTemplateDelegate: template]; //template];
            [_trackLayer addGraphic:location];
            //template = Nil;
I've got the following issue.
When the user taps on the graphic, the callout is supposed to be shown. But the application crashes in some SDK assembly, to be specific:
0x0011bed8  <+0052>  tst.w r0, #255 ; 0xff
in the [AGSMapView setupCalloutUiForGraphic:mapPoint]
I've tried to use my own TemplateClass (LocationInfoTemplate) and the AGSCalloutTemplate class, both had the same result.
To debug this, i've added the following function:
- (BOOL)mapView:(AGSMapView *)mapView shouldShowCalloutForGraphic:(AGSGraphic *)graphic {
    NSLog(@"Click");
    return true;
Just to see what's in the Graphic object.
And i was surprised:
First run: _infoTemplateDelegate UIImage * 0xde9ad50
Second run: _infoTemplateDelegate __NSCFNumber * 0xde9acd0
I think i can say that the infoTemplate is NOT retained!
What's the problem here?
I'm using the 2.1 SDK, i'm using the latest Xcode (With ARC) and the latest iOS....
--Edit-- Updated tot 2.2.1 SDK, same behavior.
NimeshJarecha
You should create a retain property for  AGSCalloutTemplate *template.
Regards,
Nimesh
ReneNijkamp
I've added the following to my header file:
    LocationInfoTemplate *_locationInfoTemplate;
@property (nonatomic, retain) LocationInfoTemplate * locationInfoTemplate;
But it still fails.
I miss the old-skool Retain command, but i can't use it when using ARC.. 😞
NimeshJarecha
Did you do following? And it still crashing?
self.locationInfoTemplate * template = [[LocationInfoTemplate alloc] init];
//AGSCalloutTemplate* template = [[AGSCalloutTemplate alloc] init] ;
self.template.titleTemplate = @"${Username}";
self.template.detailTemplate = @"${TimeStamp}";
        symbol: pointMarker
                                                   infoTemplateDelegate:self.template]; //template];
Also, you're using geometry engine in following code line. I hope you are initializing it. Like, AGSGeometryEngine *_geometryEngine = [AGSGeometryEngine defaultGeometryEngine];
If you are doing all above then please attach your sample project so I can have a look at it.
Regards,
Nimesh
ReneNijkamp
Forgot to include in my comments:
I'm looping through a dictionary while executing the above code.... (I'm adding a couple of graphics to the layer)
NimeshJarecha
My last response helped you any way? If not, attach your sample project.
Regards,
Nimesh
NoureddineEl-zaatari
Regards,
Nimesh
hello,
im facing the same problem after converting the project to ARC, im adding AGSGraphic to the graphics layer in a loop, when i click on the graphics point to show the callout, it gives this error
AGSCalloutTemplate respondsToSelector:]: message sent to deallocated instance 0xfd807a0
thanks for any help
NimeshJarecha
Did you create a strong property for AGSCalloutTemplate?
in .h file
@property (nonatomic, strong) AGSCalloutTemplate *calloutTemplate;
in .m file
@synthesize calloutTemplate;
self.calloutTemplate=[[AGSCalloutTemplate alloc]init];
Regards,
Nimesh
AaronConnolly
If you loop through a dictionary and create multiple AGSInfoTemplate objects, be sure to put them in a retained (strong) NSMutableArray or some other data structure. That should keep them around when the graphic is tapped.
GaryThorne
can any one help me please... i want to show detailed page when user tabs on accessory button? i do not know how as i am new to iOS .
