Hi all,I have a python script where I'm trying to perform a Euclidean distance on a feature class to generate a raster. The map units are meters so it outputs the cell size in meters as an integer format. I want it in miles, so I multiply by a constant to convert to miles. This, however, does not change the integer data format to a floating point. Is there any way to specify or convert the output Euclidean distance data format to FP so I can get an output as FP?Here is the line of code I'm using in the script:OutEucDistance = (EucDistance(src_layer, "", resolution, "")*0.000621371192)
Thanks for the help,-Andy
