I am using ArcGIS 10, and trying to do the following:
I have a layer file of points, and I would like to calculate the distance from each point to the nearest "eastern" polygon (U.S. state). I know there are tools for calculating distances from points to polygons (e.g., Near), but I don't know how (or, if you can) specify the direction of the polygon.
In addition, I need the output units to be in meters or miles (not decimal degrees).
Any suggestions?
Thanks in advance.
