mcolangelo
customize template picker in editor
Discussion created by mcolangelo on Apr 16, 2012
Latest reply on Apr 23, 2012 by mcolangelo
Hi all,
This is a simple look and feel problem. I am using successfully template picker in editor but ..
I want to customize template picker look and feel in panel. How can I set css item to customize appeareance of template picker panel, including tool tip box width and so on . Can you give me an example showing ho to set css and various template picker property ?  I mean:
grid  Define styles for the grid node that displays the templates.
groupLabel  Define styles for the group labels. Only applicable when grouping is enabled.
item  Define styles for the node that contains the template label and symbol.
itemLabel  Define styles for the template labels.
                   .itemLabel{color:#266A2E;}
itemSymbol  Define styles for the node that contains the template symbol.
selectedItem  Define styles for the node that contains the template symbol.
templatePicker  Define styles for the template picker.
tooltip
Thanks a lot.
michele.
Outcomes
