AnsweredAssumed Answered
Closest Facility/Delete Identical Tool Help
Question asked by estipe on Apr 10, 2012
Latest reply on Apr 12, 2012 by estipe
I am having a bit of a time figuring out a work around for a problem I have. Essentially, I ran a Closest Facility operation on a set of about 200 points. Each point is an entrance to a building, and the underlying network is walking paths. I have named each of my facilities and incidents based on building number, and ran the operation so that each building was a facility as well as an incident, producing routes to and from each building.
What I am looking for is for any given path, (1-2, 1-3, etc.), I would like the shortest route (in time). In the Route output, there are routes for each entrance. For example if building 1 has four entrances, there will be four routes from building 1 to building 2. I only want the shortest (time-wise) for each route.
This is where I thought I would be able to use the Delete Identical tool. I advanced sorted the table, first based on the name of the route, then on the travel time. After this sort, the first unique record for each route name (1-2) had the shortest time. However, Delete Identical appears to delete all but the lowest Object_ID. This is a problem because as the routes were created and subsequently exported, they did not go in the order that I want now, so the lowest Object_ID is not always the shortest time for a specific building to building route.
Any suggestions/comments would be much appreciated.
eric
Outcomes
