I'm struggling trying to construct a relationshipQuery that populates an infoTemplate
var template = new esri.InfoTemplate();
template.setTitle("${site_code} - ${facil_loca}");
template.setContent(getWindowContent);
map.infoWindow.resize(250,250);
var facils = new esri.layers.FeatureLayer("https://mydomain.com/MapServer/0",{
mode:esri.layers.FeatureLayer.MODE_SNAPSHOT,
infoTemplate:template,
outFields:["*"]
on feature click, getWindowContent() is fired, which constructs the infowindow dijit.layout's
function getWindowContent(graphic){
//make a tab container
var infoTabCont = new dijit.layout.TabContainer({
style: "width: 100%;height:100%;background-color:transparent;"
}, dojo.create("div"));
//display attribute info in first tab
var cp1 = new dijit.layout.ContentPane({
style: "background-color:transparent;color:White;",
title: "Details",
content: "FacID: " + graphic.attributes.site_code + "<br /> Fac Name: " + graphic.attributes.facil_name
//create 2nd tab for related info
var cp2 = new dijit.layout.ContentPane({
title: "Cmd Structure",
content: getRelatedData(graphic) //this is the problem <-----------
//add the content panes to the tab container
infoTabCont.addChild(cp1);
infoTabCont.addChild(cp2);
return infoTabCont.domNode;
the content for the second tab fires getRelatedData(), which *should* construct a relationshipQuery and return related data to populate the infowindow tab
function getRelatedData(graphicObj){
var objid = graphicObj.attributes.OBJECTID_1
var relatedFacMain = new esri.tasks.RelationshipQuery();
relatedFacMain.outFields = ["*"];
relatedFacMain.relationshipId = 0;
relatedFacMain.objectIds = [objid];
graphicObj.queryRelatedFeatures(relatedFacMain, function(relatedRecords) {
console.log(relatedRecords)
on feature click, I get the following warning in firebug: "graphicObj.queryRelatedFeatures is not a function"I know all the parameters for the relationshipquery are correct, I plugged them into the relationshipquery sample and it works fine.any advice?thanks!
