kass3
in ToolValidator, how to update dependencies?
Discussion created by kass3 on Apr 9, 2012
Latest reply on Apr 17, 2012 by kass3
I want to have a Field type parameter draw values from one of two other Feature Class parameters in my custom tool. When the user selects option 1, FC 1 is enabled and FC 2 is greyed out, and vice versa for option 2. When option 1 is selected, the Field parameter finds the values and populates the dropdown, but when option 2 is selected the dropdown is blank. I need to add code into the ToolValidator class to change the dependency of the Field parameter from FC 1 to FC 2, depending on which is enabled. Here is my code:
# param[1] is the "option", param[2] and param[4] are FC1 and FC2, and param[9] is the Field
class ToolValidator:
  """Class for validating a tool's parameter values and controlling
  the behavior of the tool's dialog."""
  def __init__(self):
    """Setup arcpy and the list of tool parameters."""
    import arcpy
    self.params = arcpy.GetParameterInfo()
  def initializeParameters(self):
    """Refine the properties of a tool's parameters.  This method is
    called when the tool is opened."""
    if self.params[1].value == "Use Existing Intersect":
      self.params[9].parameterDependencies = [2]
    elif self.params[1].value == "Build New Intersect":
      self.params[9].parameterDependencies = [4]
    return
  def updateParameters(self):
    """Modify the values and properties of parameters before internal
    validation is performed.  This method is called whenever a parameter
    has been changed."""
      self.params[2].enabled = True
      self.params[3].enabled = False
      self.params[4].enabled = False
      self.params[5].enabled = False
      self.params[2].enabled = False
      self.params[3].enabled = True
      self.params[4].enabled = True
      self.params[5].enabled = True
    else:
Also, a side question: can the ToolValidator class code be added to my script code, or must it be edited within the tool properties?
Any help on this would be much appreciated.
Outcomes
