I do this in kind of a round about way. ON creation I add an ID to the graphic.this.highlightGraphic=new esri.Graphic(geometry, sym);
this.highlightGraphic.id="highlight";
this.map.graphics.add(this.highlightGraphic);
Then you can dojo.forEach(this.map.graphics.graphics, dojo.hitch(this, function (g){
if(g&&g.id==="highlight"){
//remove graphic with specific id
this.map.graphics.remove(g);
does that help?as many have read by now, I've got a data grid populated by a spatial query, and corresponding points in a map (red circles).
when you click on a record in the table, I would like a graphic added to the map to highlight (green circle) an already existing point(red circle). when you click a different record in the grid, i would like the first highlighter to disappear, and a new one appear.
right now, things go 2 ways, either the selected point never clears, and it adds more and more graphic points, or the last of the red query point graphics to be drawn disappears.
how do i specifically remove a graphic from selectedRepGraphic, not just the last graphic added, which is what happens now?
function onRowClickHandler(evt){
var clickedRep = grid.getItem(evt.rowIndex).rep_no;
var selectedRep;
var selectedRepSymbol = new esri.symbol.SimpleMarkerSymbol();
selectedRepSymbol.style = esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE;
selectedRepSymbol.setSize(10);
selectedRepSymbol.setColor(new dojo.Color([0,255,0, 1]));
dojo.forEach(map.graphics.graphics,function(graphic){
if((graphic.attributes) && graphic.attributes.rep_no === clickedRep){
selectedRep = graphic;
var selectedRepGraphic = new esri.Graphic(selectedRep, selectedRepSymbol);
selectedRepGraphic.setSymbol(selectedRepSymbol);
var selInfoTemplate = new esri.InfoTemplate("Sales Rep: ${NAME}", ("${*}")); //"Rep # : ${rep_no}", "Address : ${ADDR1}");
map.infoWindow.setTitle(selectedRepGraphic.getContent("${NAME}"));
map.infoWindow.setContent(selectedRepGraphic.getContent("Sales Rep: ${NAME}", "Rep #: ${rep_no}", "Address : ${ADDR1}"));
selectedRepGraphic.setInfoTemplate(selInfoTemplate);
map.infoWindow.show(selectedRepGraphic.geometry);
if (selectedRepGraphic != undefined){
map.graphics.remove(map.graphics.graphics[map.graphics.graphics.length - 1]);
map.graphics.add(selectedRepGraphic);
return;
return;
