mblosser
Trying to Select Parcels from a MapServer with a SpatialQuery with an ArcMap 10.00
Discussion created by mblosser on Apr 5, 2012
Latest reply on Apr 6, 2012 by mblosser
I am accessing a  MapServer that has a parcel layer that I am trying to select taxlots with a both a spatial query and an attribute query.  I am accessing the MapServer with a url and am not part of the user AGSusers or Admin groups.
The spatial query is based on a local shape file. Seems simple enough but I get the following error message from  Fiddler:
???Layer not found.7>5 y??H??V?~? "esriCarto.MapServer???
The local shape file and the MapServer layer are both in the same projection.
I am accessing the Mapsever with an IAGSServerConnection Connection.  Code is below:
Dim connectionProperties As IPropertySet = New PropertySetClass()
connectionProperties.SetProperty("Url", "http://www3.multco.us/ArcGIS/Services")
Dim obj As System.Object = Activator.CreateInstance(Type.GetTypeFromProgID("esriGISClient.AGSServerConnectionFactory"))
Dim PEnumSoName As IAGSEnumServerObjectName = AGSServerConnection.ServerObjectNames
            Dim pSOName As IAGSServerObjectName = PEnumSoName.Next
            PEnumSoName = AGSServerConnection.ServerObjectNames
            Do Until pSOName Is Nothing
                If pSOName.Name = "BaseMap/Taxlots" Then Exit Do
                pSOName = PEnumSoName.Next
            Loop
            If pSOName Is Nothing Then Exit Sub
            pName = pSOName
            pMapServer = pName.Open
            Dim pMapServerInfo As IMapServerInfo = pMapServer.GetServerInfo(pMapServer.DefaultMapName)
            Dim pMD As IMapDescription = pMapServerInfo.DefaultMapDescription
?????????????????????????????????????????????????????????????????????????????????????????????????????????Add Mapserver layer to Toc???????????????????????????????????????????????????????????????
pMSLayer.ServerConnect(pSOName, pMapServer.DefaultMapName)
            'Add layer to map
           t pMap = mxDocument.FocusMap
            pAV = pMap
            pMap.AddLayer(pMSLayer)
            pAV.Refresh()
????????????????????????????????????????????????????????????????????????Create Spatial Filiter with Attribute query????????????????????????????????????????????????????????????????????????
Dim pSpatialFilter As ISpatialFilter = New SpatialFilter()
            pSpatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelWithin
            Dim sabFeatClass As IFeatureClass = featureLayer.FeatureClass
            Dim sabfeature As IFeature = sabFeatClass.GetFeature(0)
            pSpatialFilter.Geometry = sabfeature.Shape
            pSpatialFilter.GeometryField = sabFeatClass.ShapeFieldName
            pSpatialFilter.WhereClause = "NAME LIKE" + Space(1) + "'" + "UNITED" + "%" + "'"
Dim QRecSet As IRecordSet = pMapServer.QueryFeatureData(pMD.Name, 0, pSpatialFilter) ???Code fails here
            Dim Reccursor As ICursor = QRecSet.Cursor(True)
            Dim row As IRow = Nothing
            Dim Feature As IFeature = Reccursor.NextRow
            While (Feature) IsNot Nothing
                Dim Geometry As IGeometry = Feature.Shape
                    ??????do some stuff??????.
            End While
How should I be creating the spatial filter? Do I have to create it with a servercontext,
ISpatialFilter pSpatialFilter = pServerContext.CreateObject(
    "esriGeodatabase.SpatialFilter")as ISpatialFilter;
If I need to create the spatial filter with a ServerContext does anyone have some code that shows doing this with a URL?
Should I be doing something to specify that the Spatial Filter is based on a local shape file?
Should I be using a different type of connection, possibly with the ESRI.ARCGIS.ADF.Connection.AGS Namespace?
Can someone point me in the right direction?
Thanks in advance for any guidance that you can provide.
Best Regards,
Margo
Outcomes
