parsonz
Loop Fields and replace values based on an expression
Discussion created by parsonz on Apr 5, 2012
Latest reply on Apr 6, 2012 by mdenil
Hi
I have several columns within my dataset and i need to change the value of each row dependant on whether it is  =-1 or != -1.
My thoughts where to create a list of fields, loop through those and then use a search cursor to loop through each row and perform the expression.
The trouble I have is how I pass the field name to the row . I've posted my code below
import arcpy
input = r"C:\Users\Claire Parsons\Documents\GIS\Stratford LSA\Working\Stratford LSA.gdb\LCP\Stratford_3c_with_constraint_1" # your feature class
fieldList = arcpy.ListFields(input,"Max*") #create field list using only fields that begin with max
rows = arcpy.UpdateCursor(input) #create serach cursor
for field in fieldList:
        for row in rows:
        if row.? == -1: #how do i pass the field to the row?????
            row.? = 0
        elif row.? != -1:
            row.? = 1
        rows.updateRow(row)
print "\nDone.\n"
del row
del rows
Outcomes
