I have tried to install the ArcGIS for IOS SDK (version 2.2 released yesterday) and am receiving the following error:
Title: There were errors with the installation. You may want to try installing again. Message Body: The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Has anyone run into a similar problem in their iOS development environment and have any recommendations?
Troubleshooting I have performed: 1. As suggested above, I have tried re-installing multiple times. Each time, cleaning up before re-installing by running ${HOME}/Library/Application Suport/AGSiOSSDK/uninstallAGSiOSSDK 2. I have tried downloading version 2.2 multiple times in case I had a 'corrupt download'. This is not the problem either as I continue to receive the same error. 3. After each attempt, I would confirm that there was no successful install (besides the error message) by seeing that there was no folder created called ${HOME}/Library/SDKs/ArcGIS
My iOS dev environment (outside of using the the ArcGIS for iOS SDK) has been running fine with no problems for the last year or so - as I can use all of my iOS dev tools fine, deploy to my test devices fine, etc.
Any other troubleshooting tips you can share would be appreciated!
The install package was not able to create 'Templates' and 'Project Templates' folder due to permission issue at ${HOME}/Library/Developer/Xcode. It worked after creating those folders manually and making sure that they have read/write permission.
